I've started to work in a chemical company which uses packed column distillation as a seperation technique and i am trying to understand the system.
- First of all when i was student, i didnt learn the effect of bottom circulation rate for a distillation column. If i always use constant steam amount in reboiler i should always vaporize the same amount of bottom content. So what is the effect of circulation rate(reboiler flow rate)? What will change if it is 100.000 kg/h or 500.000 kg/h?
- Second question: we changed the packing types so our pressure drop in the column decreases. However after changing them we face a problem. Top temperature starts to increase when we increase the feed flowrate (by the way feed flow is all vapor), so control system increases the reflux rate and after that bottom temperature drastically drops. When bottom temp. decreases control system automatically increases the reboiler steam rate, again resulting in top temperature increase.
As a result we were expecting to increase column capacity but now we can operate with less feed rate than before. Our capacity drops. I suspect about flooding but i dont know what to do.
That's all, thanks already...
P.S: Quality of top product and bottom product is still the same
Edited by despy, 10 December 2012 - 12:46 PM.
