Acetic Acid Production By Cativa Process
Posted 20 December 2012 - 09:39 AM
Currently, I'm designing Acetic Acid plant using the Cativa process. Encountering some problems and would like some advices on that.
The methanol and carbon monoxide carbonylation process to acetic acid requires homogeneous Iridium complex catalyst which HYSYS or Unisim don't have it. According to the patents, the catalyst will flow out of the reactor and get separated at the flash tank as a liquid stream and recycled back to the reactor. Since I don't have that particular component in HYSYS, I cannot simulate the catalyst being separated from the product stream at the flash tank. Is there anything that I can do to go about this issue? And are there any information on the iridium carbonyl catalyst if there is a need to do a hypothetical component for this catalyst in HYSYS/UniSim? Thanks in advance.
Posted 20 December 2012 - 11:32 AM
I don't have specific experience for this acetic acid application, but for a similar case involving a licensor technology reactor I used the component splitter in HYSYS to mimic yield information and component separations where it was not possible to include in the simulation directly.
The other option that you mentioned is to create a hypothetical component in HYSYS to mimic the catalyst, provided that you have all the physical and thermodynamic properties available. Unfortunately I don't have this information for you. Maybe ask the Licensor?
I hope this helps.
Posted 02 January 2013 - 11:40 AM
Yes you will have to make a hypothetical component. I did my bachelors thesis on Cativa Process, although it is not a hi fi thesis but it is good and has good refereneces of patents where I think you will be able to find some information on the iridium catalyst. If you can post your email add, I will be able to send my thesis in pdf format to you.
Hope that this is of any help.
Posted 02 January 2013 - 10:54 PM
http://en.wikipedia..../Cativa_process
I believe there is a pdf file in there that can be helpful. I wish you well.
Posted 14 January 2013 - 09:38 AM
Posted 19 January 2014 - 12:47 AM
can u send me ur project too
Posted 08 February 2014 - 08:34 PM
im having some problem in doing my mini project acetic acid plant..in case of that, im glade if u can share your project to be as my reference..here is my email amri_dxii@yahoo.com...tq
Posted 17 May 2014 - 06:29 AM
im also having some problem regarding the production of acetic acid by the cativa process. If you can kindly share your project with me, it would be helpful. Here is my email hafifi.mha90@gmail.com
Posted 03 September 2014 - 05:44 PM
I cannon't find information about the production of acetic acid by the cativa process, im glade if anybody can help me
thanks
#10
Posted 28 February 2015 - 09:12 AM
Hello.
I'm currently a fourth year engineering student.
I have as my final year project is the production of acetic acid, and we have to use aspen Hysys or Aspen plus for the design of the plant.
We are going with the cativa method as our route of production.
But we are stuck at finding the kinetics of the reaction. And it's been more than a week trying to get them.
I was wondering if anyone can provide any help regarding the kinetics of the reaction.
It would be much appreciated.
Thanks !
#11
Posted 28 February 2015 - 09:16 AM
Can you please send me it also??
I have a project regard the production of AA and Cativa is our route.
We are stuck on the kinetics of the reaction, we can't Proceed with Hysys unless we know the kinetics.
Anything will be much appreciated !
This is my email: shaheedelfarra@gmail.com
Thanks !!!
#12
Posted 18 February 2016 - 09:06 PM
Hey,
I have run to a similar problem. Can you please email me anything tat you think can help me through the process?
My goal is to produce acetic acid from methanol. The overall process is natural gas to syngas through partial oxidation, then syngas to methanol production. The last sept is o go from methanol to acetic acid.
If you can email me anything to help me with ASPEN Plus set-up of the cativa process, please do so at shahketul26@gmail.com
Thank you!
#13
Posted 29 March 2016 - 09:51 PM
Can you send me your project too, please? Thank you!
#14
My email: mfelipepinheiro@gmail.com
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
