Boiler Acid Cleaning
8 replies to this topic
#1 h_eghbaly
h_eghbaly
Posted 21 January 2013 - 08:16 AM
In boiler acid cleaning by citric acid.
without addition of ammonia, citric acid will dissolve Fe II and Fe III oxide. why we must add Ammonia to the boiler?
when we must add ammonia in this stage?
In last stage we must H2O2 to the boiler.
what is the goal of this stage?
what is the reation between H2O2 and Iron in this stage?
thanks.
#2 Atttyub194
Atttyub194
  • 80 posts
Posted 25 January 2013 - 01:41 AM
Good day!
Acid washing of Boiler should be considered as Last resort and is very risky operation. In my experience i have never seen acid cleaning successful and is only required if the water chemistry has not been controlled. However, caustic wash or boil out to be done to remove dirt , oil , greese in the boiler
#3 markymaark
markymaark
  • 116 posts
Posted 25 January 2013 - 01:48 PM
Without knowing what you're talking about.. perhaps the citric acid is for passivation. Then ammonia, a base, is added afterwards for neutralization even though ammonia is not the norm.
#4 isbarqi
isbarqi
  • 26 posts
Posted 27 February 2013 - 05:02 AM
as far as I know, in boiler acid cleaning/pickling, we don't have to add ammonia. acid cleaning is definitely for scale and rust removal, so, all we need to do just dissolve that scale stuff with proper material. citric acid is one of them. besides, many acid can do that. HCl, H2SO4 is stronger, but more corrosive, usually need more corrosion inhibitor in order to prevent that cleaning agent for attacking the metal equipment it self instead of just dissolving the scale.
at last, we need to make a coating on the metal in order to prevent it from corrosion by making a metal oxide layer. it called passivation. H2O2 is one of passivating agent. also, there are many other passivating agent you can find, such as hydrazine, sodium nitrite, and DEHA.
#5 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 27 February 2013 - 06:44 AM
Thanks to above members for supplying useful info. Alumina plants (Bayer process) use caustic cleaning systematically and  acid cleaning (say once per year) to clean equipment and piping from scales.  Acid cleaning was with diluted H2SO4 plus corrosion inhibitor, but details of cleaning procedure are not known to me. Some scale cleaning info (not dedicated to boiler) can be seen at < http://www.cheresour...scaling-problem>.
Can you clarify what form of ammonia is used? An aqueous solution (content?) or a salt?
#6 isbarqi
isbarqi
  • 26 posts
Posted 27 February 2013 - 07:01 AM
Ammonia? in the common industrial cleaning equipment, as far as I concern, ammonia can be used for alkaline cleaning. it can replace caustic as degreasing agent because its ability to dissolve oil, grease, or fats. You might find it on some household cleaner as well. ammonia is not for descaling, but degreasing indeed.
another use of ammonia on cleaning industry is for passivation of steel combined with citric acid and oxidizing agent. more reference on : www.vecom.nl/english/documentation/tb/TB-2005-17-eng.pdf
aqueous solution usually been used
Edited by isbarqi, 27 February 2013 - 07:05 AM.
#7 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 27 February 2013 - 07:46 AM
Thanks, reference indicates that ammonia + oxidant are introduced to the boiler water for passivation, (say) 1.5 h after introduction of citric acid. It should be NH3 aqueous, neutralizing citric acid (pH goes from about 1.5 to 9.5).
#8 isbarqi
isbarqi
  • 26 posts
Posted 27 February 2013 - 08:27 PM
Thanks for the information. I even don't know that detail yet before.
I'm working on chemical cleaning specialist contractor, but I'm still rookie, fresh graduate. need more experience.
#9 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 28 February 2013 - 03:02 AM
Interesting job, <http://www.cheresour...bitor-lab-test/> might be also useful.
