I'm a new chemical engineer working in a bulk chemicals manufacturing plant and I'd like some help in understanding the steam ejector which makes use of superheated steam to deliver powder into a milling system.
Some of the technical specifications of the steam ejector:
Primary nozzle throat diameter: 15.8 mm
Primary nozzle exit diameter: 22.6 mm
Venturi throat diameter: 101.6 mm
Ratio of specific heat capacities: 1.31 (steam)
Mach number calculated from area-mach relation = 2.1889
Process conditions:
Steam (stagnation) pressure: 12.2 kg/cm2g = 1.298 MPa
Steam (stagnation) temperature: 271.88 C = 545.07 K
If I use isentropic equations to solve for the nozzle exit pressure and temperature based on the above mach number and process conditions, I get:
P = 1.241 MPa
T = 312.68 K
What I don't quite understand from the final results is that the absolute pressure is above atmospheric and the temperature is below saturation temperature, which doesn't seem to be the case as suction pressure is created in the actual process and superheated steam shouldn't be condensing.
Perhaps I have done it the wrong way and I'd appreciate if someone could point it out for me.
Thank you!
