Good day,
I'm having some trouble with the holding time calculation for a LNG tank.
In the attached xls file you have the calculation, please review it.
I got the max heat flow to the tank through daily evaporation loses and entalpy difference from loading to discharge.
The safety valve open at 6 bar. With that info i calculated that the first opening of the
safety valve will be in 28 days (not sure about that calculation).
How would I calculate if this setup would hold for 60 days
within the required parameters? For now, I presumed the heat flux through the
insulation at 2W/m2 ?
If I left something out in the xls file please let me know.
Any help is appreciated, thank you very much.
