Adsorption Dryer For Compressed Air
#1 rameshbeemani
rameshbeemani
  • 15 posts
Posted 31 January 2013 - 11:28 AM
An adsorption dryer with 16 bar inlet pressure (max) at 45 deg c inlet air temperature, with a flow rate of 5cfm,using activated alumina .
#2 thorium90
thorium90
  • 1,073 posts
Posted 31 January 2013 - 11:59 AM
This topic sounds real familiar...
I shall provide you a paper to read, hopefully it will start your research proper.
Edited by thorium90, 31 January 2013 - 12:01 PM.
#3 rameshbeemani
rameshbeemani
  • 15 posts
Posted 02 February 2013 - 10:40 AM
An Heat less  adsorption dryer with 16 bar inlet pressure (max) at 45 deg c inlet air temperature, with a flow rate of 5cfm.
1.Dessicant : Activated Alumina
2.bulk density : 0.764 gm/ml
3.size of balls : 5 mm (Spherical)
4. Surface area : 398 m2/gm
5.Pore volume : 0.46 cc/gm
6.Bed Crushing Strength : 94%
7. Loss of Attriation : 0.18%
8. Adsorption Capacity @ 60% RH : 21.51%
9. Loss on Ignition(1000 deg c) : 7.2%
10 . adsorption time : 5 minutes
11. Pressure build up time : 1 minute.
12. Regeneration : 4 minutes.
13.Purge loss 14% of inlet flow.
14.Pressure dew point : -40 deg c.
15.Change over : Automatic.
With the above data how to size a dryer? is the data enough?what other factors to be considered? Please advice.
#4 Art Montemayor
Posted 02 February 2013 - 12:28 PM
This water adsorption sizing topic has been discussed and explained many, many times in the past - complete with detailed sizing instructions, sketches, and recommendations.
Please use the SEARCH feature in our Forums to find the various threads and their attached material that can be downloaded by yourself.  The purpose of our SEARCH feature is to eliminate the repetition of information that has already been submitted.
#5 rameshbeemani
rameshbeemani
  • 15 posts
Posted 02 February 2013 - 03:51 PM
Dear Art Montemayor sir.
iam unable to find the related topic in the forum .
Heat less adsorption dryer to adsorb moisture from air  please advise sir.
#6 rameshbeemani
rameshbeemani
  • 15 posts
Posted 05 February 2013 - 09:08 AM
Dear mr.shaggydeep .Iwant to design a compressed air heatless pressure swing dryer whose flow rate is 5cfm,inlet air temperature is 45 deg c and max inlet pressure is 16 bar .and you can see other details in the 3rd post
