Hi
i will just be real quick. Hopefully a kind soul comes along to explain this alright!
I am modelling a fired heater aka furnace in hysys to preheat a feed to the desired temperature before entering a reactor. In hysys, there are several modules that can achieve this. Some of the more pertinent variables are the air/fuel ratio, type of fuel etc. I understand tat the fired heater module is dynamic (or is it?) so it is unable to simulate a steady state heating process. But would you recommend other modules such as a conversion reactor, heater and heat exchanger combined units to achieve the same objective? If yes, dear moderators, which would you advise on and why?
Thank you for your time and valuable experience!
