Safety Relief Valve Flowing Temperature
#1 August
August
  • 38 posts
Posted 08 February 2013 - 05:11 AM
A distillation column, the overhead is protected by a safety valve which is set at 3 barg. When the cooler fails, the safety valve opens. When the safety valves opens, is the temperature the boiling point of the top product at 3 barg?
#2 thorium90
thorium90
  • 1,073 posts
Posted 08 February 2013 - 06:34 AM
Well it should be. Although I'm curious about the actual concern for the question?
#3 Bobby Strain
Posted 08 February 2013 - 11:44 AM
There are lots of methods used to analyze distillation column relief. It's not enough to ask about a single variable.
#4 Anup87
Anup87
  • 34 posts
Posted 13 February 2013 - 01:32 AM
HI,
I am in agreement with Bobby.  Relief temperature in the event of Cooling failure may be the boiling point of the top product at relief pressure.  However, it is recommended to simulate the system at relief pressure, which will use reduced reboiler duty at relief.  This relief simulation will give you correct result in terms of exact relief rate and relief temperature required at relief pressure.
Thanks!
