Hello Folks,
I am designing a CO2 absorption tower. The primary objective is to determine the height and diameter of the column.
The feed gas composition is specified.
The exit gas composition is specified.
The solvent in is assumed to contain no co2.
The Temperature and pressure of the inlet feed gas and column is specified.
Design selection:
Counter-current, differential operation
15.2% MEA solution
To calculate the solvent flow, Kohl, 1997 suggests using 0.5 mol CO2/ mol amine rich gas loading, However I used values suggested by P. Chattopadhyay, 2007 based on empirical data given as 0.35 mol CO2/ mol amine rich gas loading . I then used modified Sherwoods correlation to find the diameter.
The problem I have is that the calculated diameter is too large (approx 7m). I have use various packings, increased the strength of the solution, used a higher pressure loading % but still the lowest value i could possibly get was ~4.5m. These diameters fall within the allowable loading % limit of 50-85%.
The problem I figured is that the gas flow rate is too high. So the question is, is having a large diameter good justification for having 2 towers with split flow? I found this to decrease the diameter to within ~2-3m which is reasonable. I know that large diameters cause channelling which is why they are best avoided. Or is having a tower of that diameter ok?.
This is not an industrial design, so please understand that I am not trying to complicate the design but trying to simplify it as much as possible in order to move forward.
If further data is required to answer those questions please let me know.
Edited by Human6, 02 April 2013 - 08:30 AM.
