Dear CHE Experts,
For a compressor station with centrifugal type compressor in which cases we may need to go for pressurized shutdown of the compressors? For this case I suppose suction and discharge ESD valves should be closed and compressor station is at its settle out conditions. Correct me if I am wrong.
Could you shed some light that:
1. Usually the seal gas source is taken from compressor discharge. If compressor is held at settle out condition then how the seal gas should be supplied? should we think about external source of seal gas?
2. During a recent Hazop meeting, one recommendation is raised to design compressor with the capability of start-up from settle out pressure. After negotiation with compressor vendor, they believe that by implementing this recommendation they have to select a more powerful compressor motor with higher rated power. Instead, they have proposed to perform partial depressurization of the compressor initiating from settle out pressure down to compressor suction pressure and then start-up the compressor from suction pressure.
I am not sure how much time saving we can gain if our compressor can be started from settle out pressure in comparison with suction pressure or zero pressure? Based on your experience is this common design for compressor motor to have this capability of start up from settle out pressure after keeping the compressor at pressurized shutdown condition?
3. Is there limitation of start-up of the compressor per hour? because there may be concerns for motor overheating upon several start up of the compressor.
4. Based on your experience how long the compressor station pressurized shutdown at settle out pressure can sustain? If this is too short such that we can not resolve the problem and subsequent depressurization is unavoidable then I do not see too much benefit with provision of this capability. What is your idea?
5. If the compressor is at pressurized shutdown state at settle out conditions, what will happen to u/s and d/s units? do we need dump valve to flare at suction to continuously route the gas to flare? How about d/s units? for example if we have gas dehydration unit at d/s then what will happen if u/s compressor is at pressurized shutdown state?
In my case the process line up is as follows:
Oil production unit => Gas gathering compressors => Sales gas compressors => TEG gas dehydration Unit => Fuel gas station, lift gas compressors and export gas pipeline.
6. If we want to re-start the compression train with pressurized casing (I suppose suction and discharge ESDV is closed) then what is the sequence of start-up? for suction ESDV the pressure is lower because compressor is at settle out pressure. So when to open the suction ESDV and how to overcome this higher pressure?
