Dear All
Good day!
It is correct that generally there is no need of installing HC and normally , it is very difficult to maintain an online analyzer in the field and to be very honest, I have not seen such an analyzer installed in filed for such monitoring for power boilers or furnaces operating on Natural gas.
The objective for such installation is not clear at least to myself and when you go a techno economical study you may not find it economical
I have specified oxygen and combustion analyzer i.e. basically CO analyzer , which were in turn used to reduce excess oxygen thereby increasing the efficiency of combustion/ boiler .
Flue gas analyzers now available have fuel types and their chemical compositions programmed in its' memory. Therefore, when the analyzer is used to to measure flue gas temperatures and either the O2 or CO2 levels, it instantly and automatically calculates and displays boiler efficiency. Accordingly, option for adjusting the setting to maximum efficiency are available and we as design engineer normally provide such option , however, operators prefer to adjust the parameters manually.
Acid dew point analyzer may be an other source of fuel economy, however, I personally prefer to do manual adjustment with safety margin of at least 10-20 Deg C due to huge implication in case of malfunctioning of analyzer
Regarding your query for range , it may be selected using chart attached starting from maximum to minimum and analyzer are available in market with this range. However, for CO analyzer the optimum range is ( 0~3000 ppm)
I am attaching one more document by one of the CO analyzer manufacturer for your information, which may be helpful for you
Best regards and God Bless You
Ahmed Attyub
Comb_Presntn_CCO_5500_TrainCust_200701.pdf 260.13KB
6 downloads
Edited by Attyub194, 14 April 2013 - 11:24 AM.
