Hello All
Am currently working in an Air Separation unit,where we have two 3 stage Motor Driven Centrifugal Air Compressors.
In design case both Main Air Compressors are supposed to run with a discharge pressure of 9.7 bar A and flow of 5000 Nm3/hr from each Compressor .But currently both the Compressor are running on unequal load ,while one Compressor is running in max load with full IGV opening and flow of 6300 Nm3/hr,the other Compressor is running in Min load with minimum IGV and antisurge valve being opened.Although at downstream we are maintaing steady flow as per design.
My first question is Why is this happening.
Secondly on consulting the Vendor they have installed a energy saving module which resulted in BOV closing of both machines,but still IGVs of both machines are not at nearly equal opened.So obviously power consumption is also varying.At Compressor discharge we have flow of 5100 Nm3/hr and 5300 Nm3/r respectively as against 5000 Nm3/hr.So the power consumption of each machine is 624 KW and 690 KW(As against the Guarantee Figure of 600 KW for each).On interrogation vendor says the additional flow of 100 Nm3/h and 300 Nm3/hr is resulting in an enhanced Power Consumption of 24 KW and 90 KW respectively.I was not satisfied with this reply.
Would Like to know is there any thumb rule or detailed calculation on what is the ratio of Power increase per 100 Nm3/hr extra withdrawal
Bodhisatya.
