I have been doing a flash separation calculation using a pressure drop as the energy input prior to a distillation column and have come across issues in the sizing of the flash vessel. I have used the Rachford Rice Equation to determine the stream compositions and flow rates and am satisfied with the results as it is completely what i expected.
The result are in the attached spreadsheet and it can be seen there is a very low flow rate in general.
When sizing the vessel (using a similar design approach as in http://www.chemicalf...00ab&topic=8913) for these low flow rates i have ended up with a diameter of the vessel of 0.026m and a calculated liquid height of 14m with a hold up time of 5 minutes.
The values seem way out of proportion for the design specifications for any pressure vessel and it would be very impractical if this were used for the final design.
My question is would it be possible to increase the diameter of the vessel to reduce the required height whilst keeping the desired volume of the vessel (approximately twice the volume of the normal liquid level) constant and then using the solver function to minimized the difference in volumes from the required volume and that calculated using a set L/D ratio. I know this shouldn't be a design specification or a criteria for the design of the vessel but i am unsure of how else to obtain a reasonable vessel size. And are there any errors within my understanding or calculations of this unit operation.
Any help would be greatly appreciated.
p.s. I have completed an aspen plus simulation of the entire process however I am now trying to understand the mechanisms involved and justify the use of certain parameters within the distillation column and do a sizing of the flash vessel for costing purposes then move on to size and cost calculations for the distillation column.
Edited by ravion143, 06 April 2013 - 07:07 AM.
