Fbion:
The regeneration (the same as the adsorption) calculations are done once the basic data is established for the drying unit. Part of the basic data is the established drying and regenerating time that you wish to impose on the unit. This used to be called a NEMA cycle (I don’t remember why; I think it is in respect to a complete sine curve defining a cycle) and it details all the steps in the complete cycle of an adsorber bed: switching, purging, heatup, cooling, pressurization, and switching. The number and type of steps (and the time allotted to each) may vary, depending on the application.
Normally, I always designed my adsorbers to operate in accordance to my operator’s working schedule. This is done a lot because the adsorption cycle is semi-batch in that beds have to be switched on a scheduled basis. It is very wise to have your operators present to administer or supervise the switching of the beds – whether manually or automatically. If that is the case, then popular NEMA cycles are 16 hours (4 hrs heating, 4 hrs cooling; 8 hours drying), and 32 hours (8 hours heating, 8 hrs cooling; 16 hours drying). As you can probably surmise, this basic data has already been set by your engineering contractor who did the original calculations and specified the fabrication of the unit. You need to have the original adsorber calculations and specification (data) sheets. Those will tell you what you have inherited plus what contingency there exists (if any) in the basic design. You cannot vary any part of a set NEMA cycle without affecting another part of the cycle. If you extend the heating time, you have to reduce the adsorption time. The beds are already sized for a given NEMA cycle and you can’t play around with the establish cycle beyond the contingency allowance given in the basic bed design. If you are forced to extend the heating cycle, you are in trouble with your operating requirements because your drying capacity will be reduced per bed and this will force more regenerations and result in less adsorbent life, and other negative results. This all means that what you are doing is indeed very important prior to accepting the turn-over of this dryer from the contractor.
What you can do is increase the heating temperature exiting the heater. Raising the regen temperature means you need less regen gas flow rate. However, you are limited by the allowable design stress in your units materials of construction. This information should also be in your data sheets. Normally, I would expect an engineering contractor to design in such a manner so as to maximize the profit – by using conventional steels (such as A516 Grade 70). This limits the allowable temperature to approximately 500-600 oF. When applying molecular sieves, I have always used as high a temperature as my vessels, piping, and valves would allow and this usually turned out to be 600 – 700 oF. Molecular Sieves regenerate better at higher temperatures.
I presume you have used the Ergun equation to calculate the pressure drop across the bed – both for adsorption and regeneration. Make sure that you evaluate the up-lifting effect on the bed as it relates to the calculated pressure drop. Any bed movement caused by an excessive pressure drop means adsorbent attrition and dusting – both of which mean a lot of trouble for the operations and maintenance.
You haven’t furnished any basic data so that I can’t specifically comment on any one topic within your drying unit’s design and operation.
