Dear All
Good day!
The ASME Code B31.8 covers the design, fabrication, installation, inspection, and testing of pipeline facilities used for the transportation of gas. This Code also covers safety aspects of the operation and maintenance of those facilities. Detailed scope is described in Appendix Q '
I will be obliged if same is referred before using interpretation of the code. For convenience , it may be noted that the code does not apply to :
- Design and manufacture of pressure vessels covered by the BPV Code or ASME Boiler and Pressure Vessel Code
- Piping with metal temperatures above 450°F (232°C) or below −20°F (−29°C) (For low temperature considerations, see para. 812.)
- Piping beyond the outlet of the customer ’s meter set assembly (Refer to ANSI Z223.1/NFPA 54.)
- Piping in oil refineries or natural gasoline, extraction plants, gas treating plant piping other than the main gas stream piping in dehydration, and all other processing plants installed as part of a gas transmission system, gas manufacturing plants, industrial plants, or mines (See other applicable sections of the ASME Code for Pressure Piping, B31.)
- Vent piping to operate at substantially atmospheric pressures for waste gases of any kind
- Wellhead assemblies, including control valves,flow lines between wellhead and trap or separator, offshore platform production facility piping, or casing and tubing in gas or oil wells (For offshore platform production facility piping,refer API RP 14E.)
- The design and manufacture of proprietary items of equipment, apparatus, or instruments
- The design and manufacture of heat exchangers
- Liquid petroleum transportation piping systems (Refer to ASME B31.4.)
- Liquid slurry transportation piping systems (Refer to ASME B31.11.)
- Carbon dioxide transportation piping system
- Liquefied natural gas piping systems (Refer to NFPA 59A and ASME B31.3.)
- Cryogenic piping systems
Coming back to the subject, one may apply the referred code for design of the subject let down station, however, interpretation done by one of our college is not correct and probably he may have not gone through complete requirement of code . Therefore, I felt it is essential to elaborate the requirements so that any limited or partial application would not lead to a hazardous situation / design /or its use by any body resulting ina safety incident
First of all , I would suggest to please refer 845.1 " Basic Requirement for Protection Against Accidental Over pressuring" which idicates that every pipeline, main, distribution system, customer’s meter and connected facilities, compressor station, pipe type holder, bottle-type holder, containers fabricated from pipe and fittings, and all special equipment, if connected to a compressor or to a gas source where the failure of pressure control or other causes might result in a pressure that would exceed the maximum allowable operating pressure of the facility (refer to para. 805.2.1), shall be equipped with suitable pressure-relieving or pressure-limiting devices. Special provisions for service regulators are set forth in para. 845.2.7 "
Therefore, we can not over rule requirement of relief valves or safety devices
Additionally, please refer 845.2.1, " Control and Limiting of Gas Pressure in Holders, Pipelines, and All Facilities That Might at Times Be Bottle Tight " which states that " Suitable types of protective devices to prevent over pressuring of such facilities include:
(a) Spring-loaded relief valves of types meeting the provisions of BPV Code, Section VIII
Pilot-loaded back-pressure regulators used as relief valves, so designed that failure of the pilot system or control lines will cause the regulator to open
© Rupture disks of the type meeting the provisions of BPV Code, Section VIII, Division 1
Before going into further discussion, I am referring the same para 845.2.4 as referred by one of our college as such
a. " Each high-pressure distribution system or main, supplied from a source of gas that is at a higher pressure than the maximum allowable operating pressure for the system, shall be equipped with pressure-regulating devices of adequate capacity and designed to meet the pressure, load, and other service conditions under which they will operate or to which they may be subjected.
b. In addition to the pressure-regulating devices prescribed in para. 845.2.4(a), a suitable method shall be provided to prevent accidental over pressuring of a high pressure distribution system.
Suitable types of protective devices to prevent overpressuring of high-pressure distribution systems include
- Relief valves as prescribed in paras. 845.2.1(a)
and (
- weight-loaded relief valves
- a monitoring regulator installed in series with the primary pressure regulator
- a series regulator installed upstream from the primary regulator and set to limit the pressure on the inlet of the primary regulator continuously to the maximum allowable operating pressure of the distribution system or less
- an automatic shutoff device installed in series with the primary pressure regulator and set to shut off when the pressure on the distribution system reaches the maximum allowable operating pressure or less. This device must remain closed until manually reset. It should not be used where it might cause an interruption in service to a large number of customers.
- spring-loaded, diaphragm-type relief valves
Careful review of the above para do not give any indication for over ruling the requirement of relief valves or safety devices . However, such provision is available for service regulators under 845.2.7 with limitation of maximum allowable operating pressure of the distribution system to 60 psig (410 kPa) or less and regulator connection to 2" NPS. This provision is not available for the referred case
Please go through " Control and Limiting of the Pressure of Gas Delivered to Domestic, Small Commercial, and Small Industrial Customers From High-Pressure Distribution Systems para 845.2.7
Regarding slam shut valves as described earlier that requirement of safety relief valve can not be eliminated, however, it may be designed to reduce temporary pressure surges downstream of the pressure regulator caused by fluctuations in system operations. The set point of a safety relief valve is always lower than the set point of the slam-shut valve.In this cases, use of a small vent valve or PSV may serve the purpose . However, such consent is definitely also required from local bodies / Authorities.
Hope I may have clarified the requirements
Best regards and God Bless you
Ahmed Attyub
Edited by Attyub194, 01 May 2013 - 01:33 AM.
