Posted 19 April 2013 - 05:11 AM
PRANAV
Posted 19 April 2013 - 08:12 AM
Effective mean temperature difference is nothing but the corrected LMTD after applying "LMTD correction factor".
Posted 20 April 2013 - 04:07 AM
up to my knowledge EMTD & LMTD not same. WE are use EMTD only for the air cooled heat exchanger not for the shell & tube heat exchanger.
Posted 25 April 2013 - 03:02 AM
EMTD = LMTD * F
F = correction factor.
Posted 07 May 2013 - 01:42 PM Best Answer
EMTD also includes an additional correction factor which is called a "temperature distortion". In effect, this factor may not affect the overall thermal design to a great extent in most cases. This temperature distortion is a factor used to account for the thermal ineffectiveness due to leakage bypass streams (fractions of shell side fluid that so not take part in direct heat transfer). In case you have access to HTRI software, you may want to read their help topic for better understanding of this.
Dipankar
Posted 08 May 2013 - 03:09 AM
Thanks.
pls solve my another doubt, EMTD used only for air cooler heat exchanger or both (sell & tube heat exchanger).
In HTFS softwear this guidelines available.Any another source available for this guidelines.
regards
pranav
Edited by PRkumar, 09 May 2013 - 04:36 AM.
Posted 09 May 2013 - 01:05 AM
Hi Pranav,
It is used for both. However, I will not be able to talk much on Air Coolers as my knowledge is limited in the same.
Dipankar
Posted 09 May 2013 - 04:41 AM
As u say in post 5. IS THERE ANY OTHER SOURCE AVAILABLE FOR "TEMPRATURE DISTORTION".because i do not have HTRI SOFTWEAR .
REGARDS
PRANAV
Posted 14 May 2013 - 02:41 AM
Hi Pranav
You may read a book called "Practical Thermal Design of Shell and Tube Heat Exchangers" by Rajiv Mukherjee. This concept is beautifully explained.
Dipankar
#10
Posted 01 May 2014 - 04:07 AM
Hi Pranav,
Do you have "Practical Thermal Design of Air-Cooled Heat Exchanger" written by Rajiv Mukherjee also?
