Hi, can the Napier's equation also be used to estimate the steam consumption of an ejector if you're only given its nozzle bore size and the steam pressure? or not?
Napier's Equation
Started by rche, Apr 21 2013 11:58 PM
Posted 21 April 2013 - 11:58 PM
Posted 24 April 2013 - 02:37 PM
rche,
http://www.gutenberg...ml#chapter_flow
http://www.cheresour...booster-system/
Hope this helps.
Shivshankar
Edited by Shivshankar, 24 April 2013 - 02:37 PM.
Posted 01 May 2013 - 11:53 PM
Shivshankar,
Thank you for the links.
rche
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Derivation Of Differential Equation For A Trickle Bed Catalyst SphereStarted by Guest_Herakles_* , 23 Mar 2023 |
Antoine Equation QuestionStarted by Guest_panoska_* , 10 Feb 2023 |
Continuous Stirred Tank Reactors Equation: Unexpected TrendStarted by Guest_Molibdeno_* , 06 Aug 2022 |
