Fallah,
Thank you for reply.
1.I used Stainless Steel 301 with OD 10 mm and Thickness 0.04 in my experiment fix this plate between two plate of brass and then increase a pressure ,this pressure monitor with indicator connected to pressure transmitter.
pressure increase up to disc rupture when disc burst i can view a max point of pressure goes down.I test this plate and burst pressure is 220 bar
2.I found formula for this experiment in http://www.roymech.c...ics/Plates.html.Stainless steel 301 UTS is 758 MPa
in this formula pressure calculate 1.5 bar
Im confused about this.I try to take a picture on my experiment device and then upload.
Best Regard
Babak Farhadi
