Cs2 & H2s Separation
#1 Guest_Guest_vishwanath_*_*
  • guestGuests
Posted 16 February 2006 - 05:24 AM
Dear friends ,
Is there any method to separate CS2 and H2S gases which is coming at 230 deg C since in our industry they are letting it to flare seal.If there any please mail to me
bye
#2 Guest_Hamadi_*
Guest_Hamadi_*
  • guestGuests
Posted 16 February 2006 - 05:05 PM
I dont think anyone want to separate H2S from CS2.
#3 Guest_HelpNASA_*
Guest_HelpNASA_*
  • guestGuests
Posted 17 February 2006 - 08:51 AM
I had a short assignment at a PPG chlo-alkali plant in Natrium, West Virginia, USA. One of their processes produced CS2 as a product, and involved H2S removal and subsequent conversion to S in a Claus plant. You might be able to get some information by starting on the web at PPG Natrium.
Sorry, but I won't post any contact names, since I don't have their permission to do so.
#4 Guest_KHANGIRAN_*
Guest_KHANGIRAN_*
  • guestGuests
Posted 23 February 2006 - 02:05 AM
QUOTE (Guest_vishwanath_* @ Feb 16 2006, 01:54 PM) <{POST_SNAPBACK}>
Dear friends ,
bye
hi
pls explain more about your problem. do you want separate H2S from CS2 , or H2S&CS2 from other gases.
what is your process flowrate? if your process flow is low you can solve your problem with membrane tech.
with regards
saeid
  • guestGuests
  • 0 posts
Posted 26 February 2006 - 07:50 AM
In our industry H2s is burned as fuel in heater.it is waste material of us. u can use it same like fuel
#6 Guest_KHANGIRAN_*
Guest_KHANGIRAN_*
  • guestGuests
Posted 27 February 2006 - 02:39 AM
QUOTE (sundar @ Feb 26 2006, 04:20 PM) <{POST_SNAPBACK}>
dear sir
in which industries H2S burn as fuel.if it is possible pls. explaine me about your process.
with regards
saeid
#7 Guest_Guest_pradeepdk_*_*
  • guestGuests
Posted 01 March 2006 - 05:12 AM
QUOTE (Guest_vishwanath_* @ Feb 16 2006, 05:24 AM) <{POST_SNAPBACK}>
Dear friends ,
bye
Cs2 boiling point is 45 Deg C. SO by cooling the vapour from 230 to below 45 can condense cs2 that will separate most of the cs2 in the vapor mixture. For higher purity u can go for vapour absorption in oils available in the market or also u can try with ethyl amine extraction method
