I came across a safety valve sizing problem with following parameteres:
Flow= 65710 Kg/hr of Process Gas with mol wt = 28.02
Set pr = 36 Kg/cm2g with 10% overpressure
Normal temp = 41
Rel temp = 240 C
k= 1.4
z= 1, no superimposed back pressure
As per API 520, the area comes out to be 26.7 cm2. Hence orifice N is selected having areaa of 28 cm2.
When we put this data in Aspen Flare Net for Flare header sizing, the rated flow for this size comes out to be 59498 Kg/hr. and hence the software requires either normal flow to be changed to a value lower than this rated flow or the orifice designation to be changed to P type with higher area.
i think that the PSV size selected is adequate enough for the relief rate of 65710 Kg/hr. However i do not understand that how the rated flow is coming to be less.
please advice.
