Dear All
I am currently trying to design water - water Shell and Tube Heat Exchanger, the data available to me is:
Hot Stream: T in = 105 oC T out = 40 oC Flowrate = 111.5 m3/ hr
Cold Stream T in = 35 oC T out = 95 oC Flowrate = 110.0 m3/ hr
Using the book "Process Heat Transfer" by Kern, while desiging i found the Number of tubes to be 5000, each 6m long having 1.25in OD. I believe this number is wrong because the datasheets availabel at the back side of the back has the Maximum shell ID to be 39in and can maximum accomodate around 1000 tubes.
please help me on this and let me know what is the mistake. also, if anyone of you has a good spreadsheer to calculate and desing heat exchangers i would be very thnakful if you could share it with me.
