Putting the catalyst in the shell side of a tubular reactor is a silly and non-sensical idea. Where did you come up with that?
Any engineering student should first start using his common sense before entertaining an idea. Common sense alone should tell you that the idea is not practical - nor advisable. Catalyst is always put in the tubes.
Study the attached drawing of the tubular reactor I helped a Spanish student design. This was a copy of a similar reactor type I had manufacturer for me by DWE in Germany in 1969. I had four reactors built to these same details and the actual reactors are still working and producing Furfuryl Alcohol in Geel, Belgium where I installed them. In fact, the last I heard, the reactors were producing 100% over design - over 43 year later! That was one of my best projects as a Project Manager.
Tubular Reactor Rev2.xls 49.5KB
116 downloads
