Filter Coalescer On Teg Column Outlet Stream (Gas)
#1 Ali-Jabbaran
Ali-Jabbaran
  • 15 posts
Posted 11 May 2013 - 07:23 AM
Dear Friends
I have a part of P&ID for dehydration outlet gas filter coalescer.
Have anyone known the reason for level instruments on upper side of coalescer?
Regards.
  • Attached File  1.JPG   63.88KB   20 downloads
#2 Bobby Strain
Posted 11 May 2013 - 09:42 AM
There is a separate chamber for the filter elements. Go to the Peerless site and check out a drawing.
#3 Ali-Jabbaran
Ali-Jabbaran
  • 15 posts
Posted 11 May 2013 - 10:21 PM
Thanks Bobby
But why is the reason for liquid level at upper side?
I think coalescer will cause tiny droplets adhere and collect at bottom of the filter.
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 12 May 2013 - 01:21 AM
Ali-Jabbaran,
There will be liquid collection on the tube-sheet. Please note that the flow in the filter separator is from inside to outside of the filter elements. Whatever liquid that coalesces while flowing through the filter elements will form a liquid level on the tubesheet since the tubesheet is sealed from the bottom section (feed inlet). Refer the attached sketch:
Hope this helps.
Edited by ankur2061, 12 May 2013 - 01:26 AM.
#5 jrtailor09
jrtailor09
  • 158 posts
Posted 12 May 2013 - 01:25 AM
Dear Ali,
As there are chance of the liquid carry over ( E.g Liquid Carryover will be less than 0.1 US gal/MMSCF).
For equipment sizing we have to consider this requirement. However, It is depend upon the equipment manufacturer.
We had purchased from same vendor Peerless. Kindly ask vendor regarding more details.
Jatin Tailor
#6 Ali-Jabbaran
Ali-Jabbaran
  • 15 posts
Posted 12 May 2013 - 01:55 AM
Thanks very much for your reply.
