Hi All
I have completed the design of a cryogenic air separation plant which produces pressurised nitrogen and oxygen for pipeline delivery to the customer and a crude argon product.
The process utilises the compact plate and fin heat exchanger before entering the double column set-up (High pressure column, low pressure column and a combined condenser/reboiler).
I am looking for documentation of advice on the start up of such plants. Performing a google search led me to the following document:
http://pubs.acs.org/....1021/ie070975t
This document is great for the start up and shut down of the process after the initial start-up procedure, as it uses a temporary storage system of process liquids, so that distillation liquid sumps can be introduced on startup. However i am looking for information on the very first start up of the plant, which i cannot find any information on.
The only idea i have is to introduce a refrigeration unit, to bring the air inlet stream to the high pressure distillation column feed temperature, however this would just flow up the column and no heat/mass transfer would occur because there is no liquid present in the column? Would i need to have a refrigeration unit which provides a liquid stream to the top of the column (replacing the reflux during start up), and a feed stream (6 bar, 100.6 K, dew point) to the bottom of the column (providing vapour flow up the column).
I also have to get the liquid sump in the low pressure column, to provide the heat transfer for the high pressure column reflux. This i suppose could be done by drawing the liquid off of the low pressure column, going through the JT valve and entering the low pressure column as a liquid, this will flow down the column and form the low pressure column liquid sump, the refrigerant which was initially entering at the top of the high pressure column can gradually be switched to the reflux leaving the condenser/reboiler?
This is total guess work on my behalf. Please help!!
George
