Dear friends,
Aspen EDR software gives the following results:
Mean shell metal temperature = 307F
Mean tube metal temperature = 290F
Minimum tube metal temperature = 200F
Maximum tube metal temperature = 300F
One source claimed expansion joint is required if the metal temperature difference is greater than 90F. However, this source did not elaborate if the difference refers to the mean temperature or max/min temperature.
Appreciate your comments if expansion joint is needed for the above conditions.
