Dear members,
I need your help in calculation of efficeincy of a two phase seperator which is installed in the Urea production section of our plant. The only available data I have with me is as attached. The stream contains CO2 vapours which requires separation of water vapours from CO2 gas.
I need to find out what is the efficeincy of the vapour liquid separator at which it is working. The only problem I am facing is that the our DCS dont display any flow data nor their are any flow instruments installed in the field in this area. I have been asked to find out the separator efficiency making use of temperature and pressure data that is available on the DCS. Please suggest me the approch I may use to calculate its efficiency.
zebmech
Edited by zebmech, 22 May 2013 - 05:39 AM.
