We have an intersatge cooler with separator installed after the first discharge of Process Air Compressor in Ammonia Plant. Due to fouling and other unknown factors it efficiency is degrading. I am assigned a task to calculate its performace.
While studying its design sheet, I found that it's a finned tube heat exchanger with separator installed within it. I need your help in calculating its overall heat transfer coefficient. Also, suggest me how do I calculate the effective surface area of finned tubes.? Data available is as attached.
zebmech
Edited by zebmech, 29 May 2013 - 05:10 AM.
