Drift Eliminators In Cooling Tower
drift eliminators
#1 harshchem55
harshchem55
  • 12 posts
Posted 29 May 2013 - 08:45 AM
I wanted to understand the usage of drift eliminators given in cooling towers. How does it eliminate the drift losses.
#2 Atttyub194
Atttyub194
  • 80 posts
Posted 29 May 2013 - 10:32 AM
Dear harshchem55
Good day
In every cooling tower there is a loss of water to the environment due to the evaporative cooling process. This evaporation is usually in the form of pure water vapor and presents no harm to the environment. On the other hand, drift, is the undesirable loss of liquid water to the environment via small droplets that become entrained in the leaving air stream. There, water droplets carry with them chemicals and minerals, thus impacting the surrounding environment
Drift eliminators are designed to capture large water droplets caught in the cooling tower air stream. The eliminators prevent the water droplets and mist from escaping the cooling tower. Eliminators do this by causing the droplets to change direction and lose velocity at impact on the blade walls and fall back into the tower. Efficient drift eliminators will keep drift losses to less than .001% of the re-circulating water flow rate.
Best regards and Good Bless you
#3 UNMESH BISWAS
UNMESH BISWAS
  • 5 posts
Posted 29 May 2013 - 05:34 PM
Sirs,
Can you classify major types of drift eliminators available in the market. Can anyone please throw some light on the material of construction also.
Unmesh
#4 breizh
  • 6,715 posts
Posted 29 May 2013 - 06:09 PM
Drift eliminators on top of the tower and  on side are "plastic made" .
Take a look at the document attached
#5 harshchem55
harshchem55
  • 12 posts
Posted 30 May 2013 - 01:35 PM
Dear sirs,
Thanks a ton to all.
