I am trying to size an orifice plate to make pressure drop and turbulency for mixing of demulsifier with produced water.
the necessary pressure drop is 0,5bar and the pipe size is 4'' GRP.Since we have different flow rate for SOP to EOP
I can not decide which size is suitable for orifice. at the beginning the flow rate is 1,52m3/hr but at the end it will be 17,215 m3/hr and the orifice size for making 0,5bar pressure drop is from 10 to 30mm. We can not use 32mm for SOP because the pressure drop will be negligable and we can not use 10 for EOP since the pressure drop will be too much.
Also another question is type and standard size of the orifice.is eccentric orifice is suitable in this case?
please advice me
Rayhaneh
