I have an Ethanol tank of gross capacity 450 m3 (total volume = 469 m3).
Storage press = 1 atm
Storage temp = 30 deg C
Tank height = 8.75m
Tank dia = 8.125m
No insulation to the tank.
I want to size a vent condenser for the same.
I referred API 2000 and considered normal thermal venting scenario. I calculated the surface area of the tank followed by Q using Q = 63,400*A^0.338 (ref. pg - 8 section 4.3.3.2.1 table 1-B for metric units)
Latent heat of vaporization of ethanol = 846 KJ/Kg.
T = boiling point = 78 deg C (351 K)
M = Molecular weight = 46.
Using all the above values i used equation 1-B to calculate the venting capacity. I see that it is gigantic value.
Can someone verify the calculations or share some excel sheet for the same. ? Also tell me, the thermal venting tables (2-B ) are for what ambient temperature ? because as the temperature between storage and ambient increases, venting capacity would also increase, so I believe the tables are at specific temperatures?
Thank you.
Edited by Raj Mehta, 28 June 2013 - 12:56 AM.
