Velocity From Pressure
#1 damaraju chaitanya
damaraju chaitanya
  • 6 posts
Posted 24 June 2013 - 06:41 AM
Dear all,
Nitrogen is flowing inside a pipe of known size (say 1”) at a known pressure (say 1Kg/cm²). So my question is can we calculate velocity of nitrogen at this pressure? I need to calculate the flow rate.
Are there any chemical engineering correlations between pressure & velocity (as like ERGUN equation for packed beds)
Thanks & Regards
D.Chaitanya
#2 latexman
  • 1,839 posts
Posted 24 June 2013 - 07:00 AM
Bernoulli's equation.  Be sure to study it's limitations though!  It may or may not apply very well to your case.
Edited by latexman, 24 June 2013 - 07:10 AM.
#3 breizh
  • 6,793 posts
Posted 24 June 2013 - 07:06 AM
Consider this resource and any fluid dynamic textbook!
As you can see in the attachment you need to know the pressure in 2 points and the piping arrangement .
Edited by breizh, 24 June 2013 - 05:37 PM.
#4 Steve Hall
Steve Hall
  • 167 posts
Posted 24 June 2013 - 07:07 AM
You're comparing apples and oranges. Like asking if you can know the temperature if given the pressure.
If you know the pressure at the beginning and the end of a pipe segment, then you could calculate the flow rate that results in the observed pressure drop. But that's a different question than the one you've asked.
#5 shan
shan
  • 692 posts
Posted 24 June 2013 - 07:08 AM
No. N2 flow may be various value at the same pressure condition.
#6 latexman
  • 1,839 posts
Posted 24 June 2013 - 09:16 AM
Attach a sketch labelled with all the information you know and what you want to find out.
