I am a bit confused here, please help with the basic understanding of the concept. I know that in a vacuum generation/condensing system(such as vacuum drying or pervaporation etc.) where you are trying to maintain a vacuum, a vacuum condenser is placed upstream of the vacuum pump, in order to reduce load on vacuum pump. The idea here is that due to condensation of the vaporsm in the condenser upstream a partial vacuum is created which helps reduce the load in the vacuum pump. The vacuum pump is then mostly used to pump down the system and remove non-condensibles.
But my question is this. Generally, low pressures are for flashing a liquid into vapor state, thats how flash vessels work. By reducing pressure you enocurage liquid to go into vapor phase. But here, in a vacuum condenser we seem to be doing the opposite, condensing a vapor into liquid at low pressures(because vacuum pump is pulling vacuum through the condenser). Wont this require a large surface area and very low temp. cooling fluids? How os this advantageous? The load that you reduce in the vacuum pump would be more than negated by the large surface area requirements of the vacuum condenser, isnt it? Or am i missing something? dew point is low at low pressures, whereas for easy condensation you need a higher dew point.
so how does this work? please help
