Dear sir,
As i am new to the forum so message was posted to wrong place by error, I will take due care to avoid mistake in future. Now I will again describe problem in detail.
I am running extraction column having 19 sieve trays each tray having 384 holes having 5 mm dia.feed rate from top (ammonium sulphate ) is 21m3/hr with density of 1210 kg/m3.i am not able to put more than 6m3/hr bottom feed(cyclohexanone) because of slippage of anone from tower bottom. Required rate of bottom feed is7.2 m3/hr.
bottom sparger (2") has 100 holes of 5 mm diameter in 5 rows
Top sparger (3") has 100 holes of 7 mm diameter in 5 rows
tower ID is 800 mm
downcomer area is0.05 m2
Downcomer ht is 100 mm
dist. Betn two tray is 200 mm.
can you pl.guide about reason for limitations.
Extraction Column Limitations
Started by himanshujdalal0713, Jul 21 2013 12:06 AM
No replies to this topic
Posted 21 July 2013 - 12:06 AM
Prv Vs Extraction Condensing TurbineStarted by Guest_mj311_* , 13 Nov 2024 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Aspen V11 Help On Radfrac Distillation Column ErrorStarted by Guest_savinedanglokta_* , 13 Nov 2024 |
