Flat Face Flange Weld Neck For Diesel Piping
#1 Athan
Athan
  • 5 posts
Posted 19 August 2013 - 11:25 AM
Can I use Flat Face Flange Weld Neck for Diesel Piping? The line is A105N, max design conditions are 165 deg. F and 180 psig. The diameter of the pipe and flange is 3 in.
Thank you and more power!
Best Regards,
Athan
Posted 19 August 2013 - 11:38 AM
Athan:
I would not recommend you use a flat face flange (steel or cast iron?) on a hydrocarbon fluid.
In fact, I would not use a FF flange on anything.
#3 Athan
Athan
  • 5 posts
Posted 20 August 2013 - 09:51 AM
Art,
Thanks for your reply. The material is carbon steel.
Athan
