Turbo Expander
#1 Rahimzadeh
Rahimzadeh
  • 282 posts
Posted 21 August 2013 - 08:56 AM
Dears:
what is difference between turbo expander and pressure reducing valve function in nitrogen plant?
best for all of you
M.R.Rahimzadeh
#2 gegio1960
gegio1960
  • 518 posts
Posted 21 August 2013 - 10:05 AM
rahimzadeh,
you can compare the N2 expansion to the steam expansion.
With the expansion thru the valve (letdown) you realize an isoenthalpyc process: you simply cool the nitrogen.
With the turbine you realize a (non ideal) isoentropic process that allows the recovery of work (other than cooling the nitrogen).
regards
#3 Pilesar
  • 1,554 posts
Posted 21 August 2013 - 06:08 PM
When nitrogen pressure is reduced through an expander, the resulting nitrogen is at a lower temperature than if the pressure were reduced by passing through a valve. It is the availability of using the lower temperature nitrogen for refrigeration that makes the expander such a key piece of equipment. The work recovered is a bonus. In small plants, small expanders might even be attached to a hydraulic brake instead of to a compressor or generator. The brake wastes the driving power, but allows the benefits of low temperature at a lower capital cost.
#4 Rahimzadeh
Rahimzadeh
  • 282 posts
Posted 21 August 2013 - 08:31 PM
thank you .your respose satisfied me.
