I am a Process Engineer & presently working designing the On-Spec & Off Spec Condensate Storage System.
For On Spec Condensate (True V.P = 70 KPa), I am going ahead with External Floating Roof Tank. However, I am unable to decide the type of Tank for Off-Spec Condensate. I checked with my past Projects refernces which have used ‘Fixed Cone Roof Tank’ with Nitrogen/Fuel Gas Blanketing. According to me it correct since Off-Spec Condensate is unstabilised & hence flashing. In our case, V.P of unstabilised off-Spec Condensate is ~200 KPa. Though it has low flash point.
However, my problem here is We do not have ATM Flare. So where to route blanketing gas outlet line ?? Quantity of Flash gas as Off Spec is as high as 1 MMscfd. Can i vent this much quantity to safe location based on dispersion ?? Or can I connect vent line to Low Pressure Flare (3.5 barg).
We do not have N2 generation plant & N2 is going to be purchased in Cylinders. Hence I am thinking to use Fuel Gas Blanketing. Is it OK ??
Kindly suggest.
