Hello Guys,
The rule of thumb is that the SIDE downcomer WIDTH should be a MINIMUM of 10% of the column diameter. This gives a weir length of 60% of the diameter and a downcomer area of 5.2%. The reason for this rule is to avoid stagnant liquid zones at the sides of the tray.
With respect to downcomer design:
The purpose of a downcomer is to disengage entrained vapour from the aerated liquid. In sizing the downcomer the two main criteria that need to be considered are:
Downcomer “Choke” Flood
Downcomer Back-Up Flood
The downcomer choke flood should not be based solely on an entrance liquid velocity since it is not superficial liquid velocity per se that is critical but rather the liquid residence time in the downcomer.
An entrance velocity of 0.13 m/s is a good starting point - for a standard non foaming system operating at less than 6 bar g with a tray spacing of 24”. We use a figure of 0.12 m/s (180 gpm/ft²) which translates to a residence time of 5 seconds.
For optimising tray designs, the downcomer can be sloped up to where the bottom area is a minimum of 50% of the top area. The logic behind this is that the liquid at the bottom of the downcomer is less aerated than the liquid at the top thus requiring less residence time for disengagement. Sloping the downcomer as such would give a mean residence time of 4.4 seconds.
The downcomer size (width) is de-rated pro-rata to the tray spacing.
The downcomer size (width) is also de-rated pro-rata to the system or foaming factor.
Consideration also needs to be given to the liquid through over the weir. This is quite often neglected. Ideally we do not want the liquid to strike the column wall (shell) until the liquid falls half way down the tray spacing. This will avoid premature choke flood. A method for calculating the liquid throw is given by W L Bolles (Optimum Bubble-Cap Tray Design, Part I – Tray Dynamics, Petroleum Processing, 1956, p64-80).
The downcomer back-up (flood) is a function of the following:
Dry pressure drop
Wet pressure drop
Head loss due to the liquid flowing under the downcomer
Calculated as clear liquid, the back-up should not exceed 50% of the tray spacing for a system operating at 6 bar g or less. For high pressure service above 24 bar g the back-up should be less than 35% of the tray spacing. A longer residence time is required at high operating pressure due the increased difficulty of disengaging the vapour from the liquid as their respective densities are much closer together.
The head loss under the downcomer can be reduced by increasing the downcomer clearance. However, care needs to be taken as the downcomer clearance influences the liquid flow pattern across the tray which in turn can impact on the tray efficiency.
Other methods of reducing the downcomer back-up are to use radius edge (tip) downcomer panels, inlet pans and also low pressure drop valves.
