Hi-
I'm new to the forum and have a twist on a question that seems to be repeated quite often here. I have an API 650 tank that is rated as "atmospheric" and it is NOT an appendix F tank. So, per API 650 and 2000, the MAWP should be estimated as the weight of the roof / cross sectional area of the tank (or ~1.5 inWC every time)! But these tanks also have a noted " air test pressure" ranging anywhere from 0.5 to 3 psig.
I understand all of the previous discussions with sizing relief vents for tanks that don't have a real MAWP. But, can I use the "test pressure" as the MAWP for vent sizing purposes? The problem is these tanks have been in operation for a number of years with a Nitrogen blanket of 3 inWC and current pressure vents set anywhere from 28-45 inWC. So, I don't think the MAWP is really 1.5 inWC!
Thanks for your input.
