Anybody know of any article or thread that can help explain how to draw fire circles for a given plot plan when trying to determine flow during a fire sizing case? Thanks.
How Do I Make Fire Circles In Fire Case Relief Scenario
Posted 20 September 2013 - 10:40 AM
Posted 20 September 2013 - 03:14 PM
Nowhere is a circle mentioned in the recommended practices. Maybe this will help.
Posted 21 September 2013 - 12:53 AM
For a new design, wetted area for equipments falling in 300 m2 (3200 ft2), is the area to be considered to calculate relief load for a system. If there are no physical barriers (say walls) present, fire zone shape is considerd as circular.
This is based on SHELL guidelines, hope this helps.
regards,
Varun
Posted 21 September 2013 - 09:29 AM
Most of the proects, I have used a 25ft radius horizontally and 25ft height from grade. Some clients go conservative with 50ft radius...
I believe API 520/521 also recommends something about fire circule radius/height. Its been a while I did relief design...
Posted 21 September 2013 - 09:30 AM
Usually the source of ignition are regarded as rotating machines which are spark prone...
So say, from a pump, 25 ft radius and 25ft height. Whatever comes in this zone, has to be accounted for wetted area to be exposed to fire...
Posted 22 September 2013 - 12:57 AM
If I understood the query correctly, it is reagrding the extent of ground area covered during Fire (and not height of Pool Fire i.e = 25 ft). As per API 521 (5th Edition, Year 2007), 'Ground area of 230 - 460 m2 is recommeded as the extent of Fire'. API does not mention it as a circle. However, We generally consider it to be circular & hecne term them as 'Fire Circle'.
I have not worked extensively on this activity but what I heard from my collegues is, 'We take Piping Plot Plan, Draw circles of 460 m2 area & then add the Relief / Blowdon Load of the PSVs. The Circle which gives the Relief / Blowdon quanity is considered as the maximum load for the given Zone. Flare is then sized for Zone giving highest load.
Hope it helps.
Shekhar Dhuri
Posted 08 December 2013 - 09:07 AM
Thanks everyone
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
![]() Relief Vs BernoulliStarted by Guest_JanPau_* , 16 Dec 2024 |
