I am designing a positive displacement pump, screw type for a refinery revamp project. They handle a flow rate of 18,000 bbl/h of Fuel Oil @ 130 °F and 570 cP with a design discharge pressure of 600 psig.
Art has commented on various forums the importance of relief systems of positive displacement pumps (relief valves and piping). It is clear for me that the relief pipe of this type of pumps "should not go back" to the suction line because all the mechanical and piping flexibility implications this would entail. Art suggests a return to the suction vessel. In fact, I'm very agree with him... http://www.cheresour...no-minium-flow/
But my doubt arises regarding the specific design features on which I’m working. The length of the suction line of the pump is around 400 m away. Yes, it’s a very big dike (four fuel oil tanks) because a Venezuelan law (from 1973) requires a ridiculous separation between tanks (very absurd in my opinion and experience).
The suction is performed from atmospheric Fuel Oil tanks of 433,000 (nominal capacity). According to the mentioned criteria, the relief lines from pumps to tanks must travel a long distance. The relief system (valves and pipes) were design to handle the design flow of the pump (18,000 bbl/h), so, I have a very long line of a considerable diameter back to the tanks.
My questions are, is it strictly necessary to do this? Could I return the relief flow to the suction line respecting a considerable distance from the pumps? Will this impact the fuel tank considering its working pressure?... I don’t think so, It’s a big tank (diameter: 220ft) and It is true that the operation is not continuous and I have a ESD system for the pumps, but, would not be appropriate, given all these features (economic impact) connect the relief pipe to the suction line instead the tank considering the long distances?
In the attached file I found the following information:
“The safety relief valve outlet connection should ideally be piped back to the suction supply vessel. Piping back to the suction pipe can cause discontinuities in the suction pipe flow that can result in poor pump operation and damage. Should it become necessary to pipe the safety relief valve back to the suction piping, the connection into the suction pipe should be a minimum of 10 suction pipe diameters in length back toward the suction supply vessel away from the pump suction connection”.
Suction line diameter: 34”.
I would like to know your opinión.
Thanks.
