Well I was going through the topic of humidification and after completing the topic I was solving some multiple choice questions. I came across this question saying that when temperature increases at constant humidity(absolute humidity) what happens to relative humidity and wet bulb temperature?
As far as I my understanding goes, Since the moisture content remains the same and the temperature is increased ,Relative Humidity should decrease, which is what the answer said, but it also said that Wet Bulb Temperature(WBT) increases.!
Now as the relative humidity decreases that means the air is more dry which means that the difference between wet bulb bulb and dry bulb temperature should be more now and WBT should decrease.
Please help me with this doubt of mine.
But it says WBT increases.!!
Ayche
