There are many heat transfer books out there as well as books on heat exchanger designs including, so I guess it shouldnt be too hard to find. Others might have good recommended books for you. Still, adding heat exchangers anywhere will affect other heat exchangers too as the heat duties for others will change. One doesnt randomly place unit operations anywhere on a PFD unless you can prove its impact on other unit operations too.
Startup and shutdown procedures as well as maintenance of equipment are very specific to the plant and equipment. There is no generic way of starting a type of plant. Unless you are prepared to come up with specific detailed designs on all valves, controllers, control systems, units, auxiliary units, utilities, electrical, mechanical and process details in the entire plant by what would normally take many people in an EPC team to do, I wouldnt suggest you touch anything on it.
Just to clarify, you were given a project topic by your lecturer to upgrade an equipment in an SMR plant that your seniors have designed and you chose the boiler to upgrade?
Edited by thorium90, 04 October 2013 - 07:31 AM.
