Heat Tracing For Blowdown Lines And Valves Upstream Of Flare
No replies to this topic
#1 AralChE
AralChE
Posted 25 October 2013 - 07:13 AM
Due to an emergency  blowdown of fuel gas from buffer tank to flare header, choking flow occurs at a 3" pipe line and valve.
Fuel gas is pretreated associated gas with 3700 ppmv water in it (potentially up to 18000 ppmv).
Fuel gas MW is 23 g/mol. It is used for fuel in GE 6B GTG.
Due to excessive cooling, condensation and methane-hydrate formation seems possible therefore heat tracing may be a remedy.
Before elaborating further on the definition of this problem I wonder if there is any reference (API, ASME etc) to heat tracing for such lines?
OR does anyone have such an experience in the field?
ACA
PS: Fuel gas contains trace amounts of components of up to C10+
