Hi, is there someone here familiar with the process of crystallization? I'm doing P&ID of crystallizer and I need to know why condenser is needed and the reason why condensate needs to go back to the vessel. Hope you can help me. Thanks.
Posted 31 October 2013 - 03:05 AM
Posted 08 November 2013 - 08:48 AM
dear kylene, could you please share a small sketch for better understanding. because it may so happen that all the crystallizer units may not have the same configuration. Like what is the material that is being crystallized, what is the source of refrigerant. etc..
Posted 09 November 2013 - 02:52 PM
In some processes, vacuum crystallization is performed. In this case, the slurry is concentrated by solvent evaporation. The solvent boils, which not only concentrates the solution causing more solids to precipitate, but also cools it, decreasing the solubility of the material being crystallized. If the solvent (reflux) is returned to crystallizer, instead of being collected to a receiver or storage tank, it will not have the concentrating effect, but will still have the cooling effect. The reason for doing this is that you can typically achieve much more surface area for a condenser than a cooling jacket, and you don't have to worry about forming a thick layer of cake on the sidewalls of say, a jacketed crystsallizer. If you must use a jacket, split pipe is preferred in my opinion, especially multi-zone split pipe.
Hydrated And Anhydrous Form CrystallizationStarted by Guest_Izaaz_* , 01 Sep 2023 |
Crystallization Of Nacl With Seed CrystalsStarted by Guest_jordan1111_* , 23 Mar 2023 |
Modeling Fractionation & CrystallizationStarted by Guest_waheed2020_* , 04 Oct 2022 |
Crystallization ProcessStarted by Guest_leon_neo_* , 20 Feb 2021 |
Prevention Of Secondary Nucleation Crystallization In Plug Flow ReactoStarted by Guest_Jeannot_C_* , 16 Dec 2020 |
