Unisim To Hysys / Hysys To Unisim
Started by equilibrium, Oct 31 2013 09:16 AM
Posted 31 October 2013 - 09:16 AM
Does anyone have any experience in this transfer of a model and if so can you answer my questions.
I am running or am able to have HYSYS V7.0-7.3
Unisim version is R400.
Are .XML files the way to go. I have already ran into issues with this format.
Is it better to have UNISIM save the file as a .hsc file and the HYSYS user open the .HSC file in the version of hysys that unisim designed it for.
Posted 31 October 2013 - 09:50 AM
Since you seem to have both simulators, why don't you try the alternatives?
Posted 31 October 2013 - 09:54 AM
I dont currently have both. I am a HYSYS user and am currently waiting to get the UNISIM trial. Our client uses UNISIM.
Posted 12 November 2013 - 02:06 PM
After doing some testing the .hsc file is the way to go.
Posted 28 November 2013 - 03:52 AM
In a few trials i tried, Hysys to Unisim worked okay, but Unisim to Hysys was problematic... even using XML files.
But i might have had some version issues going on.
Glad to hear that it worked fine
