Hi everybody,
I am a process engineer working in an engineering company and designing utilities for a Refinery.
I have a concern regarding the type of block valves for LPG service: block valves up and downstream the control valve, vent to flare or connection to closed drain, double-block-bleed arrangement.
I am very confused because sometimes I see gate valves and sometimes I see ball valves.
For example, in a refinery I worked in, there were Ball valves on the overhead of a Isomerate Stabilizer, which is a LPG (C3-C4) service. We also had ball valve on LPG vaporizers, where the valves where all ball valves.
On another project I worked on, there were gate valves everywhere, except when the line downstream is connected to atmosphere, flare or closed drain = when depressurizing could occur as I understand.
Is there any rule for the use of this type of valve?
If my post is not clear, forgive me! This is my first post and I was maybe not clear enough for a good understanding of my concern.
Best Regards to all of you
