we have a liquid nitrogen storage tank at our site. it is at the end of COSTAIN's nitrogen generating plant. it works on the principle of cryogenic distillation of air. The problem we are facing for quite over a month is that our liquid storage tank keeps on venting.
the setpoint is 7.0 bar. when the pressure of vessel increases it vents some of the nitrogen to bring pressure down.
we have checked the vacuum of the LIN storage tank it is a bit crude. >1 torr
what other factors shall we check to solve the problem.
PS: its my first post. so dun mind if data is in sufficient or question isn't clear enough.
if you need data or further information i will provide u with tht.
waiting for your replies
