Cooling Tower Blow Down Cost Saving
7 replies to this topic
#1 K J
K J
  • 38 posts
Posted 20 November 2013 - 09:35 AM
normally cooling tower blow down either contineous or intermittent is done from cooling tower bottom. is it not possible to do it from cooling water return header so that blow down pumping to ETP power cost as well as pump Installation cost can be saved.
#2 fallah
  • 5,019 posts
Posted 20 November 2013 - 12:06 PM
k.j.
The location of outgoing blow down is bottom of the cooling tower basin because the concentration of dissolved solids is at the highest value there among the whole loop due to fluid stagnant condition after evaporation in cooling tower...
#3 curious_cat
curious_cat
  • 475 posts
Posted 21 November 2013 - 02:21 AM
You can try doing a lab analysis of the dissolved solids etc. at both locations. A differential will be instructive.
#4 breizh
  • 6,715 posts
Posted 21 November 2013 - 05:20 AM
What you are describing is the way the Cooling water system I was operating ( 5000 m3/h capacity) was working a couple of years ago !
You should consult vendors and or water treatment company for 2nd opinion .
Edited by breizh, 21 November 2013 - 08:25 PM.
#5 thorium90
thorium90
  • 1,073 posts
Posted 21 November 2013 - 08:35 AM
Im curious why a simple cooling tower blowdown from the tower bottom needs a pump. Isnt it already at the bottom? Or am i misunderstanding the problem?
#6 K J
K J
  • 38 posts
Posted 22 November 2013 - 02:51 AM
@ thorium  Actualy cooling tower blowdown done from basin bottom which goes to blowdown pit and from that with pump it goes to ETP.
I have given basin bottom sample to check how much it is differing from circuilation header.
#7 K J
K J
  • 38 posts
Posted 23 November 2013 - 08:08 PM
ok basin blowdown and return header analysis is as
parameter         basin bottom       return header
PH                         7.0                       7.1
conductivity           1874                    1862
turbidity                 13                        10
TS                         1398                    1396
TH                          829                     792
chloride                  206                     225
silica                      128                      119
TDS                       1358                    1354
SS                         40                        42
As per cooling water treatmnet company treatment chemicals are dosed in supply header so direct blowdown from return header will be loss of that chemicals.
#8 breizh
  • 6,715 posts
Posted 24 November 2013 - 01:30 AM
K.j .,
As stated earlier your proposal is fine to me, your system is well balanced !
