I am a junior process control engineer with no chemical engineering degree who would like some help to understand what is the better choice for controlling the fuel gas to a heater: pressure control or flow control. Attached a simple flow diagram of the process where the location of all instruments drawn corresponds to the locations in the field. It involves a natural draft heater that is part of a hydrotreating unit. The objective is tight control of the coil outlet temperature. In this particular case, there is a cascade control configuration where the master is a (coil outlet) temperature controller and the slave is a (fuel gas) pressure controller.
I have heard and read, without much detail as to why, that it is better to control the flow of fuel gas instead of the pressure of the fuel gas. The only thing that I have heard as a supporting note to this assertion is that pressure would be affected by the number of burners being on (this particular unit has low NOx burners by the way)
Note that there is a density analyser available. The chart attached corresponds to a week of readings. I thought about the possibility of using it to provide some feed forward action to the temperature controller. Unfortunately, the effect seems to be very small plus the signal comes too late to be used. What about using the density to compensate flow or pressure (probably the same issue of late signal reading and small effect)?
Could anyone share any experience or knowledge as to which option is best for effective control of the temperature and why in general and/or in this particular case?
Any explanation, ideas or suggestions would be greatly appreciated!
