One of our fellow process engineer did some calculation regarding water bath hater, His source is API 12K.
Where he has used a heat flux of 10,000 Btu/hr.ft sq deg F
Flux density of 12,000 Btu/hr.in sq
My consideration is that Api 12K is for fired heater does it apply to water bath heater design?
He has used same heat flux for fire tube design and process gas surface area calculation.
In my view the flux generated in the fire tube (Temperature Gradient) should be much higher then the flux generated in the process has tube.
My another query is that he has used a header to divide the gas flow into three separate tube. Which will also have four pass
DSC_0111.jpg 116.45KB
12 downloads(attached hand drawing) . In my view the flow through all the tubes will not be same.
Please advice
Regadrs
Edited by processengbd, 23 December 2013 - 03:32 AM.
